Wayne County Hose said:
I have a degree in electronics and know
Your comment about plastic fuel containers being spark safe or not a source of static sparks is NOT TRUE.
Dissimilar insulators can produce tremendously high voltages and resultant sparks capable of igniting gasoline vapors. Maybe your curriculum didn't cover static electricity generation much. Maybe it is too "old fashioned."
It has been well demonstrated that gasoline (a fair insulator) when flowing over plastic (gas can) generates a static charge. By law the metal gas nozzle is grounded BUT the gasoline being a fairly good insulator, insulates the gas can from the nozzle and so a sizable charge can build up on the can. It is possible for this charge to make a spark by jumping to the metal nozzle. The risk is reduced if the nozzle is kept in contact with the fuel can.
I make no claim that this is Consumers Guide check rated lethal first time every time but it can happen.
Even a dry desert wind just blowing over the car can charge the car with static electricity. The first contact of the nozzle to the car should not be the tip of the nozzle to the car's filler hole where a spark can cause ignition. If you are touching the grounded nozzle and with your other hand touch the car away from the open gas hole the charge will be dissipated. Alternatively you can touch the nozzle to the gas flap or other metal on the car before you remove the gas cap. Then insert the nozzle and keep metal to metal contact throughout the fueling.
When fueling a gasoline fueled aircraft the first thing the driver does when he gets out of the truck is to pull out the ground wire from the reel on the truck and get the ground in place. The nozzle is ALWAYS to be kept in contact with the aircraft during fueling to prevent a spark.
Sorry, if I was a bit shrill, B U T... Plastic gas cans in the truck bed, lined or not with a plastic liner or spray on or sitting on the ground can generate static sparks and need to be handled with caution. Just because they don't blow up or ignite first time every time doesn't mean they can't or won't.
There is no simple means of "grounding" a plastic can. An advantage of sitting the cans on the ground is that if there were a problem you could drive the vehicle away from it.
I use plastic cans. I fill them in the bed. I try to be careful with the nozzle to reduce risk. Maybe one day the makers of the cans will use additives in the plastic to promote conductivity so they won't build up a charge. Meanwhile...
Pat
