Maine_Polack
I have filled tires a few times. Once used Cal. Chlor. Mixed it in a garbage can and used a sump pump to get it into the tire. No special fittings are required. I do own the piece that goes onto the stem and lets air out auto now, but it is not necessary. Just plumb down from the garden hose fittings to tubing that will fit snug over the valve stem. The fittings should be available at almost any hardware store.
I used this same set up, -plumbing, not the pump- and hooked it up directly to a garden hose that was hooked to an outside faucet. If you don't need any anti-freezing ingredient, this works great.
I never even clamped on the vinyl tubing to the tire stem. Did pull it off a few times to let air escape. Perhaps once or twice would have done it. Never actually heard any air escaping, and the house water pressure would probably mostly overcome the "compressed" air.
