dangerdoc said:
Unless your budget is tight, I would look at a used commercial mower over the Husque. I looked at them and it does appear heavier duty than some of the other light use mowers but the engine is only good for about 1000 hours and I bet the deck is engineered for about the same.
A commercial mower with a diesel engine is designed to be abused and should last for decades.
There are a lot of ways to look at it. A commercial used mower used comercially for 1 or 2 years is like a home owner using it on their own yard for decades. There is no doubt they are made to last decades, so is the bx23 with the mmm. But depending on the op uses, he should get at least 5 years(at a minimum) out of the unit he just bought. So even if he had to buy it twice, it still may be cheaper then buying a commercial unit.
For me, I have been using my grandfather's 1965 cub cadet 70
1965 cub cadet 70 for mowing the yard up till last season. With leaves in the fall way out of hand and extremely time consuming, i had to do something so i wanted the cyclone rake. So i needed a tractor with more hp and the cub needed a break. So last season i bought a used scotts garden tractor
scotts garden tractor (identical to deere G100) w/39 hrs. It came with a 54" deck that never been used and a front mount snowblower for $2K. He had the reciept and paid over $5500 new. I wanted the BX24 at the time for alot of landscaping that needs to be done, but didnt think i could swing it. But this year things changed and I was able to buy the bx24 and did. So i am glad i have all three because the cub i use to pul a trailer around, the scott i use to mow with or without the CR, and the bx24 i am using for work around the yard. But before I bought the scotts, i wanted the bx24 to do everything. My grandfather bought the cub in 65' and it was built tough and lasted all these years, I wanted to do the same and buy the bx24 and be my last tractor i buy. But having all these tractors around is VERY convienent and if and when the scott tractor dies i will probably get the mmm for bx24 and I hope to use it forever since nearly all my landscaping needs will be done.
Like i said there are a lot of ways to look at it. So good luck with your purchase, but you may want to hang on to that mmm though.
