jeff9366
Super Star Member
- Joined
- Jan 14, 2011
- Messages
- 12,398
- Tractor
- Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
What size, what brand, is your three bottom plow? Are the ground contact parts undistorted and matched?
Dave5264: I read the manual, used the block under the rear left wheel to do initial setup.
Did you use 'a' block or two (2) blocks, one under the left front wheel, one under the left rear wheel?
Use a Level to check level adjustments in both planes when you start Round II.
Setup - what i think i did wrong:
on the first 2 passes (Dead furrows) I had way too much sod roll back, I had the plow on left/right tilt/cant ready for the wheel to drop in the dead furrow, so I think I should have used the leveling lever to have the plow level with the tractor on the dead furrow passes and then off set it once i got the wheel in the dead furrow.
I doubt moving the Adjusting Lever (integral to some plows) would help. Its purpose is to adjust width of cut to space bottoms equally. (If we are comprehending the same lever.)
Or are you using incorrect/confusing nomenclature for the 3-Pt. Right Lifting Rod?
Was your 'dead' furrow the correct depth (+/-) for the width of your plow? Reasonably even depth? (If the tractor wheels are going up and down, the plow will move up and down in response.
When I put the tractor and plow back in the shop and dropped the plow down, i noticed I was probable a bit too nose down and too aggressive (did initial setup on the driveway), I have now lengthened the top link a wee bit.
Good. If you only used one block under the left rear wheel, rather than blocking both the rear and front wheels for pre-adjustment, too nose down highly probable.
My main Question is this ---- > I did find the plow pushing to the left a lot, and subsequently I was having to compensate by steering left, coz the tractor wanted to go right. Im not sure if the plow being too canted left/right or the aggressive pitch (nose down) would have caused that ?? any ideas. I do know i shouldnt have to fight the plow. Of course with th eplow pushing left you dont always get 100% of the sod on the right.
Adjusting Lever, which sets width of plow furrows so they do not overlap, probably would help here, IF the plow is centered behind your tractor.
Is the plow directly behind your tractor or offset to one side more than the other?
Is the Top Link falling naturally to the middle beam on the plow? Stabilizers a little loose?
I also think my 6.5 km/h plowing speed may be a wee bit slow ? should be up around 8km/h or 5 mp/h ?
Experiment a bit. Often I set the desired engine power with the hand throttle, then adjust speed over the ground by moving hydraulic 3-Pt. control lever just 1/8" in one direction or the other, depending on soil draft resistance.
Looking forward to the next field, it started to rain so I figured Id stop and get some more advice before round 2
