DVerbarg
Platinum Member
Glenn,
Like Bird said, don't believe a word a sales person tells you at a dealer when it comes to engineering numbers.
It sounds like towing a trailer will be a sporadic activity. If the truck is to be used all the time for commuting with only an occasional tow then some of the smaller trucks can work OK if you are in flat lands and you have a large enough engine and appropriate transmission. Had a '81 GMC half-ton (6 cyl) that I used to pull a 16ft trailer. Ruined the transmission "torque convertor" locking mechanism when pulling 6000 lbs on flat roads at 45 mph for 25 miles. Transmission still worked fine, the "overdrive" just never worked again (and fuel economy dropped 3 mpg).
Since getting rid of the truck I have used my parent's Ford 3/4 ton van to tow the trailer with my TC40D. Not sure which engine they have but know that it is one of the smaller 8 cylinders. Have to baby it, even in these flat lands. Also wish I had trailer brakes. But for the occasional tow every few months, it seems to be OK. If I were going to be towing every couple of weeks I would have to get another truck. I would get a 3/4 ton Diesel. The diesels get much better fuel economy for the same amount of torque. Diesels usually last longer but the fuel usually costs a little more. My ideal truck would have the sterotypical reliability of the Toyota name, the frame and diesel engine of the Ford, the front suspension of the Chevy, and the looks of the Dodge.
DaveV
DaveV
