D
Deleted member 216442
Guest
Def38's comment regarding misoriented grease fittings also applies to the USA made Rhino I purchased used. The expensive spherical seat roller bearing I had to replace had its grease fitting oriented such that a grease gun would never get on it; hence it was run dry for too long. Probably a factory issue as the paint on it looked original and uncracked. I missed the fact that the bearing had failed when looking at it considering purchase. The bearing and grease fitting on the other end of the roller were ok. I wholeheartedly agree with the advice to buy the heavy duty blade version of any flail as opposed to the light duty blades. I spent a lot of time removing and straightening blades on the anvil right after I got it, and already bent a few.
