OP
Claytonfarms
Chrisofman, We have a bunch of different topics here, cold start and fluids.
For UTF you want something rated for Ford 134 fluid. Two of the NAPA fuild are for hydro systems like pumps and stuff, you do not want that if it says Ford 134 spec on the tractor fluid you should be ok. 5w40 diesel oil is good for the engine, it takes about 5 quarts and the same filter as a 1980s ford pickup with an inline 6 cyl, if I remember correctly an 8A or 1A filter.
The cold start works as follows:
There is a heater screwed into the intake manifold close to the inlet tube. It should have a wire to it and a fuel line to it. When you turn the key to the left, the heater is powered and gets hot. When you start it turning left, fuel is dripped onto the heater from the injector return line. This warms the air in the intake and lights the fuel dripping on the heater to help warm the intake and aid in cold starting and engine warm up. If you want to check it, see if there is power to the heater when you turn the key one click left. Wait a few minutes with the key turned left and the heater connected to see if it gets warm to the touch. If it does get warm, the heater should be working. Depending on temp you may want to let it sit a few minutes or longer to help cold starting, it is a trial and error thing. I would not let it sit for a 1/2 hour, mine usually starts after 2 minutes or so down to 15F. Once the engine starts and is running ok you should turn the key to the right run position to turn off the heater.
