pl mt farmer
- Joined
- Aug 14, 2010
- Messages
- 4
- Tractor
- ford 1920
Goodm morning all, I have a 1996 ford 2120 Hss. Bought the tractor used was sitting for a few years. the previous owner had a new clutch installed before it sat the issue is in the hss. the tractor goes fine in reverse when you shift to N the tractor often times is still in reverse. When you get it to go forward wich isnt often the engine will stall out when you release the brakes. I know the tractor was run low on fluid someone had the wrong dipstick in it when i first got it and changed fluid there was only about 4 gallons in it. took the spool valve off from below steering colum had it checked he saw no blockage in it or any reason for it to not be working. yes it worked ok when he first got it back from garage.
