ETD66SS
It is 4x4 with a full cab and loader. I think it is around 9000 lbs. Are your tires filled? Mine are not. Do you have wheel weights?
I would look at 10,000 GVW trailers for what you are doing. Then you will have room to spare on the weight rating (less room if you have wheel weights). I wouldn't want a deck-over either for my uses either. It would be really hard for me to get my street-rod on it.
I would look at getting fold up ramps with the legs that sit on the ground to support the back of the trailer. Without the legs, your tractor will lift the back of your truck right off the ground. Always block your trailer tires when loading.
No wheel weights, no loaded tires. I will say though, I do need to add front wafer weights at some point in time, but those can easily be removed & thrown in the pickup bed when hauling.
Wow, so you're towing a 9000lb tractor on a 10k GVW trailer. :O
Yeah, some ppl block, some ppl don't. I'll definitely block or get the ramps with legs.
