Diamondpilot
Super Star Member
- Joined
- Jan 18, 2007
- Messages
- 16,326
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
Diamond Pilot, you keep trashing the 3/4 ton hemi you had, you don't get over 1 hp per cubic inch without burning fuel. You don't make 350-400 hp without burning a lot of fuel. A gas engine will never equal a diesel in a heavy duty towing application for efficency, but that doesn't a make them a poor choice.
I never had one single problem with the Hemi engine. It ran like a top and did a ok job of towing but was no better than the 5.4L Ford I came out of. It was the rest of the truck that left me disappointed having many small items simply break. I had to put in a new AC compressor, 2 trannys and traded it needing work, and replacing the power steering pump. All this happened in the first 60K or so. I have owned all brands including GM, Toyota, Honda, and Nissan along with nearly a dozen Fords and non were ever in the shop this much except for a few recalls and a bad dash cluster. I did have a 89 Blazer that had the engine go at 30K and the transfer case 2 K later. This particular Dodge I had I would not drive more than 50 miles from home because it left me stranded too many times in the 2 years I had it.
Chris
