UPDATE: I had a little time to work on the PTO problem today and here are my observations. Filed a little on the shaft hoping it would help, but didn't. I put the shaft back in and the lever moves back and forth about 2-3 inches but will not completely disengage. Which is the opposite of my original problem, I couldn't get it to go in gear before.The PTO is spinning all the time and can't be disengaged. I took it back apart and with the 4 bolts removed that hold the PTO shaft in place I moved the PTO lever back and forth and when the lever is almost to the fully disengaged position it pushed the shaft out the back of the tractor about 3/4". I then removed the shaft completely and put some grease in the splines so I could tell how far onto it the gear was going, about 1". My unprofessional opinion is that due to the slight twist in the PTO shaft it is preventing the gear from moving back and forth freely on the PTO shaft to completely engage and disengage the PTO. I will have a new PTO shaft one day next week to try. Does this make sense to anyone?
