I am confused. If it was turning over why are you messing with the new solenoid?
I was thinking the same thing. If the engine cranks, the only remaining problem should be the ignition system. Some questions that come to mind are...
- Is it timed correctly? I didn't adjust timing, but it ran after I cleaned the points/distributor/etc.
- Are the points gapped correctly? I used the 0.15 shim that came with the overhaul kit. The seemed gapped just fine and the previous points where roughly 0.15 but it ran in this configuration.
- Is it wired correctly? I think so!
- Is there a ballast resistor? If so, is it good? This is a good question. Where would I be looking for this on a 12V conversion? Inline with the coil?
- Is there power going to the coil? Yes, 12.7ish voltage last time I checked.
- Are the new coil and condenser good? The tractor ran with the new coil and old condenser. I have not gotten the tractor to run with the new condenser yet.
- Are the new coil and condenser the correct parts? Yes. I bought an overhaul kit for the front mount 8N and everything fit together as it should/did when it was working.
Thanks Massey, good questions. Here are my answers for some of them.
