Look.. I'm not going to argue with you.. and you can disagree all you want. I'm not saying it is a GOOD thing to convert a worn out engine to 12v to help with starting.. I'm saying that it is a -COMMON- thing that happens.
I read a dozen or more other boards.. mostly antique boards.. and i can tell you for a certainty.. that lots of 12v conversions get done to aid in starting a tired engine.
I agree that if you are lower than spec compression, you are loosing hp. ford specs 90psi minimum.. I've seen plenty of 75 psi engine running and mowing and doing ok.. even though they are tired and would love new rings, valve job, and and sleaves.. etc.
For some people.. it is a lack of $$ for the 500$ rebuild kit.. or the 500-1000$ of labor and machine shop work to rebuild an N engine correctly.
for some it is a lack of time for the machine to be down while being fixed correctly
Still.. for others it is a lack of knowledge of how to rebuild it themselves, and not wanting to spend the $$ to get it done.
In many cases a full rebuild isn't even needed. various 'upper' or lower' jobs just to drop in rings or do valves, and drop in crank brearings sometimes pump lots of like into an old carcass.
On the flip side... while an indiovidual may not be able to do an engine overhaul in his carport.. or drop 500-1500$ to have it done.. they CAN buy a 25$ gm /delco 10-si alternator from a rebuilder or junk yard, and then cobble a bracket kit.. or buy a 30$ bracket kit, and a new 29$ walmart battery and a 5$ resistor convert their tractor to 12v, in a couple hours or less, and the extra speed that 12v system spins that 6v starter ups the average compression enough that a hard starter now starts much easier.. etc.
I'm not debating the pro / con of that issue.. just stating what i see happen every day.
When i bought my 8n, it also had an 8v battery in it.. plus an incorrect ( b-circuit ) vr. All it needed was points and condensor,a nd a 6v battery, and the correct a-circuit vr and she starts just fine. I have plenty of 6v tractors, a couple ones that were converted from 6to 12, and a few that were 12v to begin with.
Again.. I'm not sure what you are disagreeing with... I'm pointing out an observation I have made from years ov viewing online tractor sites, and hangin out with people that own old equipment..... Are you disagreeing with what i have observed then?
My opinion is the same as yours.. a worn engine needs to be corrected.. not band-aid'ed..
Soundguy
HarryVanderpool said:
I have to respectfully disagree.
If an engine is in such a high state of wear that it will not fire, it needs to be rebuilt. You are going to be down on power also.
The 9N only starts out with 21 HP.
Who wants a shot version of 21HP?
When we bought our 2N it had an 8 volt battery installed.
The seller explained that, "These things are hard startin'."
Many times when giving the farm tour people will say something like, "Look at that sweet old tractor!"
I walk around and open the gas valve, pop it into neutral, pull the choke, turn on the key, say, "I'll show you what sweet is......"
Push the starter button; "Waa waa waa RUMMMUMMUMMUMM....
Take a peek:
http://img.photobucket.com/albums/v202/Shallotman/DSC00334.jpg
