Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,238
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
if that works.. then you have a bad connection.
EASY to resolve.. vs the bandaid fix.
once you clean up the battery wire to cable and terminal connections.. coat all with grease.. tighten up..
clean , bright, tight, good for electrical connections.
loose connections arc and burn.. let corrosion in.. cause hard starts, over current, and hard charging...
