Ford YT16
   / Ford YT16 #41
Hello, in an effort to eliminate the belt as the issue, I purchased a new 48 in belt and installed it as it's installed in the diasgram above. That did not resolve the issue as I am still not having any luck getting the deck blades to move for any period of time. With the new belt, as soon as I flip the PTO switch the blades move about one revolution before the mower shuts off. Is it possible that I have the wrong size deck belt and it's too tight? The deck belt I installed after the original one broke is 5/8 x 96".
   / Ford YT16 #42
My YT18 Ford tractor with the 48" mower deck calls for a 5/8" X 48" belt. Do you have the tension spring hooked to the tension pulley bracket and also to the slot in the Mower deck?
   / Ford YT16 #43
Yes, the tension spring is attached to both the tension pulley bracket and the mower. In the previous post I inquired about the deck belt and whether it could be the source of the issue if it's too tight. I replaced the original broken belt with a 5/8 x 96 belt.
Lol, actually that was the original issue, as soon as I got it home the dck belt broke and I ne
   / Ford YT16 #44
I am attaching a diagram from my manual look at it and see if the mower decks are the same. I would think a 96" Belt would be for the Blade pulleys. I know that mine uses the 5/8" X 48" from the engine pulley to the blade drive pulley. I changed mine last week. If you could post a photo of your deck it would help.
   / Ford YT16 #45
Thanks for the patience and sorry for the confusion, I am obviously using the wrong lingo. In ref to the 5/8 x 96 inch, I was talking about the one onwith the blade pulleys. Thus far I've installed two new belts, a 5/8 x 48 one that I installed on the mower and the 5/8 x 96 belt that I installed on the blade pulleys. Will send photos of the dec and mower tomorrow.
   / Ford YT16 #47
Hello 1985 Eagle, I finally resolved the issue with the mower blades not turning on my YT16 when I flip the PTO switch. Apparently one the deck spindles was locked up due to bad bearings, despite being able to move them earlier with my hand. I went to the local Tractor Supply store, picked up a new spindle, installed it, and now I'm good to go. I included a photo of the deck that includes the new spindle, if I had been able to find the others spindles, I would've replaced them all.
All the rumors about it's cutting prowess were correct, it provides a very smooth cut, which rival that of my JD 455AWS. BTW, I got the thing fixed, cut grass for about 30 minutes, and then it started raining. Bummer!!
Thanks for all the help. I now need to tackle the brakes/clutch, as it not stoppping the mower as it's coming down a hill. Then I will address the lights, at the moment they don't turn on.
   / Ford YT16 #50
I found a YT16 with no deck for $250, in decent shape, I just sold my MF1855 and bought a smaller 18 h.p. Wizard garden tractor, similar to the Craftsman GT6000 of the 90's. I was thinking of buying the Ford as it's a bit longer wheelbase than the AYP/Wizard and appears more heavy duty. I'm going to look at it and see what I find. It would be a utility tractor and no need for a deck.
