not2old
Veteran Member
- Joined
- Oct 16, 2010
- Messages
- 1,003
- Location
- Scotch Creek, British Columbia
- Tractor
- 2010 Massey GC2610TLB
I also had my home built with 2"x6" outer walls. The insulation and cost advantages for this (in florida) is great. BUT, the heating and cooling is affected more IMO by the way air moves within the walls (put a hand by an electrical outlet when someone opens a door to the outside, and notice the air movement). After wiring 1000's of homes for many builders, sealing the penetrations from the walls into the attic area or the upper and lower floors makes a huge difference. Seal holes around the wiring and the plumbing. On of the builders had thermal imaging of a area of home and found the difference to be major. Just something to concider.
Be careful with this. Check with the building code in Vancouver, British Columbia to see what else needs to be done when sealing a house this well. When the national buiding code in Canada made these changes, the coastal area of British Columbia produced "leaky condos". A catastrophy resulted that ruined many people's lives. As usual, government denied responsibility. It has to do with when moisture gets inside the walls, it has no way out. Seattle, for example would be similar due to the rainfall.
