Qapla
Veteran Member
the best thing for those old motors is to find gas with out E85 in it.but thats like looking for a needle in a haystack.
Guess I'm glad I'm not in your neck of the woods. Around here, you are doing good if you CAN find E85. However, all the gas has 10% Ethanol.
Running the "modern" gas will probably not hurt the motor, as long as you aren't working the tractor all-day-every-day. However, I will probably result in a premature need to rebuild the carb if it has rubber seals in it. If it is old enough to have leather seals, the alcohol doesn't do them as much harm as it does the rubber.
