GA - Bush Hog 3045 Loader - New for 30-50 HP Tractor
Item Details
Type
Bush Hog brand 3045 Front End Loader for 30 - 50 HP tractors. I bought it for a New Holland TC40 but it can be used on other models and brands. It is new old stock - never taken off the pallet and stored inside. Includes hydraulic lines, operating valve and joystick, hardware, and bucket. It does not have the mounting brackets for the tractor. If you have mounting brackets, here is a new loader for less than 1/2 the cost of a new one. Asking $2500.
Bush Hog 3045 Front End Loader Specs​
Compatible Tractors
Tractors .......... Ford, John Deere, Massey Ferguson, Case IH
PTO Power Range, Hp .......... 30-50
Hydraulic Pump Capacity, gpm (lpm) .......... 10 (37.8)
Hydraulic Pressure, psi (bar) .......... 2500 (170)
Loader
Loader Model .......... Bush Hog 3045 Quick Attach Mid-Mount Loader
Attachment Type .......... Skid-Steer
Bucket Cylinders .......... 2, Double Acting
Lift Cylinders .......... 2, Double Acting
Bucket Cylinder Sizes (Bore and Stroke), in (mm) .......... 2.0 x 22.8 (50 x 580)
Lift Cylinder Sizes (Bore and Stroke), in (mm) .......... 2.25 x 19.4 (57 x 490)
Bush Hog 3045 Loader Operating Specifications
Lift Capacity to Maximum Height At Pivot Pin, lbs (kg) .......... 2350 (1068)
Lift Capacity to Maximum Height, 19.5 in (500 mm) Forward of Pivot Pin, lbs (kg) .......... 1500 (682)
Lift Capacity to 59 in (1.5 m) Height, At Pivot Pin, lbs (kg) .......... 2700 (1227)
Lift Capacity to 59 in (1.5 m) Height, 19.5 in (500 mm) Forward of Pivot Pin, lbs (kg) .......... 1850 (840)
Breakout Force At Pivot Pin, lbs (kg) .......... 4000 (1818)
Breakout Force, 19.5 in (500 mm) Forward of Pivot Pin, lbs (kg) .......... 2900 (1318)
Rollback Force at Maximum Height, 19.5 in (500 mm) Forward of Pivot Pin, lbs (kg) .......... 2300 (1045)
Rollback Force at 59 in (1.5 m) Height, 19.5 in (500 mm) Forward of Pivot Pin, lbs (kg) .......... 3400 (1545)
Rollback Force at Ground Level , 19.5 in (500 mm) Forward of Pivot Pin, lbs (kg) .......... 2800 (1272)
