jfh230
Bronze Member
It sounds like a vapor barrier problem. Typically when pouring a concrete slab you put down 4" stone over the compacted dirt, then a layer of poly vapor barrier and then pour the concrete. The stone base helps with draining away any underground moisture and the vapor barrier prevents the moisture from reaching the slab. If you don't use at least 6 mil poly then the poly will get destroyed with holes when pouring the slab. Holes in the poly allow the moisture thru.
A quick check is seal down a two foot section of the slab with plastic being careful to fully tape all edges securly. Come back in 24 hours. Moisture on the top of the plastic is condensation, moisture under the plastic is vapor barrier problems.
If you have a vapor barrier problem most sealers will not help and will make any future attempts at fixing more difficult because you will have to remove the sealer (sandblasting or shotblasting). The only product I have had any type of success with in fixing vapor barrier problems is hydraloc. Its not so much a sealer as a penetrant which soaks into the concrete and fills up all the little voids. If I remember it will go down a couple of inches into the concrete. As it cures it turns solid and becomes a permanent part of the concrete. I've had some sucess with this in older basement slabs that I know don't have a vapor barrier.
The company is enduroseal www.concretesealer.com
I think it was about $150/5 gal pail. You buy it direct from manufacturer. Keep in mind that when dealing with a vapor barrier problem the only 100% solution is to rip up the slab and install it again. Nothing you put on top is going to work 100%.
Good luck
Jack
Good luck
Jack
