I'm not thinking that people have full exposure to newer gasoline engines. They too have a significant array of sensors and emission controls. I know fleet mechanics that work on MANY things, and gasoline engines are not viewed by these folks as being any win over diesels.
My 17 year-old TDI VWs run just fine. Computers and EGR stuff included. I've cleaned intakes on two of three of these cars (third one came to be already cleaned); I don't expect to ever clean them again (variety of reasons, all which should easily eclipse the mileage that was on one car whose intake I cleaned at about 150k miles [performance was still great]).
My Kioti NX is Tier IV. Basically it's an additional DPF, which means a DPF and a couple of sensors (and software programming to monitor sensors and command regens). DPFs are rated for around 3k hours, after which they can be cleaned (once). 225 hours (a few regens) and ZERO engine problems.
ALL diesels with turbos use variable vane technologies: they have to because of the need for boost at lower RPMs (where diesels tend to run). Geez, my 17 year-old cars did/do! They also have catalytic converters, AND, injectors (huh?). They also start in cold weather
Gelled fuel is the result of fuel and temperature, not the emission spec of an engine. Sensor failures? See my comment on gasoline engines above.
Diesel engines run on oil-based fuel. Bottom ends will always go a LOT longer than an equivalent gasoline engine's.
Between the three TDIs that my wife and I operate we've put on over 110k miles (in three years): lowest mileage is my car, with only about 162k; others are over 200k miles. Plenty of sensors on these cars. All have computers. All have EGR valves. ALL have "variable wastegate[sic] turbos." All have "injectors."
The ONLY engine-related issue has been one failed MAF- yes, a "sensor" - $100- and a couple of glowplugs.
I've got a 1993 Ford F250 7.3L IDI with about 250k miles. It's my farm truck. While it always starts and runs (when I bought it with about 243k miles I had to replace all glowplugs, fuel return lines and GP controller), it's an absolute pig. I'll take direct injection and turbos any day: but my truck works well enough and I cannot justify buying something else.
