polarred21
The 1705 is a very capable little unit. You get about all a homeowner needs in the package, loader, backhoe and mower.
This is good advice....just to clarify the 1705 is FEL unit w/o BH
Anybody use their FEL to remove any sod and then the dirt below the grass?
I am really close to purchasing a MF GC1705 tractor with the DL100 loader but the only thing that is holding me up is not knowing how the DL100 loader with this tractor performs. I have 5 acres with about 2 of those being woods. We have some reservations about if the loader will actually will be able to lift loads of gravel, horse manure, dirt, sand, and also wondering if the tractor itself is strong enough to drag small trees that have fallen in the woods. Can the tractor push snow pretty good in the winter with a snow blade? I know a lot of questions but it would be better coming from a forum of users and not salesmen telling you anything you wanna hear. Its really appreciated.[/QUOTE
I can tell you from experience that the DL100 loader is more than capable of anything you mentioned. Since I bought mine I have used it for snow removal and plowing, heavy load movements like 12' by 4' galvanized steel walls, 40 yards of organic loam, 6-18 yard truck load of 2" gravel, 14-16 yard truck loads of sand, 2-18 yard truck loads of silt. 6 yards of crushed slate. I have used it to level a half an acre of gravel over what was once an 8' foot hole in the ground, sand, silt and loam. I've moved 10 yard piles of dirt in several locations. I've used it to push down trees up to 4" in diameter, move yards of snow piles and install 6 yards of mulch. I have also used it to bulldoze\lift tree trunks from trees 14" in diameter My pins are still in good shape, my tractor in great condition and my front edge on the loader is just starting to show a little wear on the outer edges. My only complaints are the grease zercs on the top linkage of the bucket are subject to breakage when moving gravel-the rocks can fall in between-however the 1705s new grease zerk design will eliminate that. The other is when trying to lift clayish dirt you will need some teeth and ;lastly I need some kind of a bucket extender so I can grab more snow at one time. She may take more trips than a full size machine but she will get the job done on 12 hours a tank of diesel. I am now at 180 hours.
