Larry Caldwell
Super Member
Just a comment about emergency water: we have a well that is reliable but gets pretty low flow in the late summer. To even out water supply, I installed a 2500 gallon cistern with a 1/2 hp booster pump, and for power outages I put the cistern on a slight rise above the house. I get about 12' of head when the cistern is full, which is enough to refill toilets and get cooking and hand washing water out of the tap. With wood heat and oil lamps, the house is comfortable without any electricity. We fire up the generator to take showers and run the freezer/refrigerator for a few hours a day. If fuel is tight, a tiny 1000 watt genny will run the freezer.
I think generators should be integrated with whole house design. I almost installed propane just for propane hot water, but my 4400/5000 watt generator will run the water heater, though a couple showers or baths will consume a gallon of gasoline. In an extended outage, it's nice to know that I can heat enough water for a nice bath in a double boiler on top of the wood stove, and the water will come out of the tap.
