Use to have 8 to 10 pigs in the back pature behind house . Had 2 strands of wire about a foot apart , with first maybe 6" off the ground . Can't remember the exact brand , Red color , was rated some godly figure in miles . Anyway , after 4 years of no issue's , Before I went to get the little ones to start the yearly process , thought I would check out the fence since I seen the neighbors dogs just go through the fence without even a single yelp ???
Not using any brain's what so ever since I could not find my fence tester , I borrowed my Father in Laws electrical meter tester . At the time in the early '80's , this meter was $50+ , so it was a higher end brand . I shoved the ground probe into the ground and touched the red probe to the wire . Even with the meter set to the highest voltage ( 2000 )) , the meter needle jumped to max , back to zero , to max , to zero , to max , then there was this " Poof " noise right when I pulled the red probe off the wire . Never thought anything about it , Better half put it back in the box and returned it .
Called My Dad and he said to add a 2nd ground rod closer to fence , since it was kind of a dry year . Several months later My father in law tried to use his meter . NOTHING on any setting ? So he took it in to the electrical company he bought it from . They pulled the back off to check it out and ended up giving him a new one . Tech said there must of been some sort of short in the circuitry as it looked like it had burned a few things !! :confused3:
Told my Dad about it and He proceeded to tell Me that the fencer I had was some were in the range of 20,000 to 30,000 volts , ( only 2 of those old 1 amp car fuses in it ) but only 1 amp , thus the range it had . The pulsing I seen in the meter needle was the pulsing of the charger and that there was a big difference between 2000 volts and 20,000 volts . :ashamed: Who Knew !
I do know that the pigs would line up shoulder to shoulder and cruise the tree's and fence line for acorns , etc.. . That would work until they pushed the first pig into the fence . He would give out a small squeal , the pigs in the middle would kind of grunt , But that last pig on the inside would come off the ground with a chillin' squeal and hit the ground with his legs doing about 60 mph + .
Never been shocked in the head , ( Guess that could be why I have issue's
) , Hands , arms , legs . But imagine with even the small amperage that a fencer puts out , it cannot feel to good to get zapped in the noggin .
Fred H.
