SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,160
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Nuts are not so important because theres a lot more thread root area in the engaged threads in the nut as opposed to the bolt. In a pinch, a grade 2 nut is sufficient for a Gr5 bolt and a gr5 nut for a gr8 bolt. Also, the washers look good with the stamp crowned side out, but they are stronger with the crowned side toward the workpiece -- The sharper edges of the flat side serve as stress risers, weakening the washer when that side bears tensile stress as it does when the bolt or nut bears on the crowned side.Informative but not complete. You are at a big box store and choose grade 8 bolts, what nuts and washers do you get?
The nuts and washers should also be grade 8. Unless marked you will be picking up grade 2 or 5 hardware.
What if you are replacing a lower grade bolt with a higher grade, no nut to screw the bolt into, the frame is tapped?
A] You drill out the tap and use the same grade nuts.
B] You use a longer bolt to thread deeper into the blind pocket.
Washers are stamped or CUT from sheet metal. The stamping causes a slight CROWN in the washer, take advantage of the crown by placing the flat side away from the bolt head or nut.
I have found that the chine's nuts and washers much too soft for the bolts.
larry
