beppington
Elite Member
Kubota dealer is 5 miles from home. JD and Mahindra are both about 35 miles away. It's dizzying for someone who is not familair with tractors to consider all brands.
If it's dizzying get the L3940 & be done with it, if you can afford it. I don't see how you could ever look back & regret it. You might only ever regret not getting it :thumbsup:
Was pretty much set on Kubota until somone pointed out Mahindra and the potential cost savings for the heavier tractor.
The rear tires on an L3940 can be filled (mine are), & at that point I don't see lacking the Mahindra's extra factory weight as pertinent. In fact, think of it this way: You can actually make the L3940 either light or heavy ... whereas the 4035 can only be heavy.
Most equipment in my area is green and I don't know a single Mahindra owner personally so I'm grasping for information.
Again with my dad's Mahindra 4110: When I told him the other day that I was feathering the 3PH control to drag my grading scraper thru soft sand precisely, barely lifting & lowering it, he commented that he wished his would do that. His takes a pretty good tug to move the 3PH control, & therefore it moves a lot, no feathering his. Also his loader control valve leaks all over the rubber floor board pad & has caused it to warp up; Not a huge deal, but. Also, his loader control valve is mounted out on the loader arm itself, requiring quite a reach to operate it. Whereas the Grand L's loader control valve is integrated into the fender, precisely located just to right of where your hand naturely rests when your arm's on the armrest :thumbsup:
I expect this will be the only tractor new tractor I ever buy so I want one that will last and have the support I need over the long haul. I'll post prices for comparison once I have them.
Thanks for all the help.
RJ
Put another way: I think you'll be just fine with the Mahindra, but the L3940 is closer to a sure thing.
