Rat,
For some reason I don't see the post that you made, I assume in this thread. I got the Reply you made to my earlier note but I just don't see the post. I've been looking for it all over and figured it out to be from this thread... Maybe I'm wrong....
Comparing the capacities of the FEL's, especially amoung different brands, I found to be as clear as mud. I never really trusted that the numbers given on the FEL capabilities were apple to apple comparisons...
Having said that, here are some numbers I pulled from Green and Orange brochures and web sites. The lift height, capacity at max height, and breakout force for the JD 460 FEL are 111.9", 2,325 pounds, and 3,863 pounds. From what I could tell only the Kubota LA 852 would work on the L4610 so I was comparing that FEL with the JD 460. The numbers on the LA 852 were 108", 2,470 pounds and 3,055 pounds. For me the most important number is the breakout force.
So the JD looked to be a bit better than the Kubota. But the are certainly very close to each other except in the breakout force. I would be curious as to what measurement the dealer provided and are they for the LA 852 FEL?
The JD FEL cylinders certainly do look small but they do the work so I can't complain. The only concern I have with the FEL cylinders is having the bucket extended down and running into something. I have heard of this bending/breaking FEL parts. But that would be true on any brand.
Later...
Dan
"Rat replied to your post at the site: .
http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=otherjd&Number=51103
Dan, there was a 460 loader sitting on the lot at my local dealer. Asked about it. He said it was for a 4700 they just sold. I mentioned that the loader arms looked kinda thin and whimpy. He agreed. I know the loader can lift, but those "toothpicks" for arms scare me. He gave me a comparrison sheet that showed the lift capacitys of the 460 VS the loader on the 4610. The 4610 beats it by a decent amount. I'm definitely leaning towards the Kubota 4610 now. The arms on it are quite a bit larger then the 460. Rat..."
