Deere Dude
Elite Member
- Joined
- Feb 10, 2011
- Messages
- 3,988
- Tractor
- John Deere 3720
Hello,
I'm building a garage on my property and currently working on preparing the site. I removed an existing concrete slab, and now I need to level and grade, as well as spread gravel. I was thinking of hiring someone to do this for me, but then I found out that my future mother-in-law has a small Ford 1510 (22hp) tractor with a rear 48-inch blade attachment. Since I've never leveled this large of a site (approx 40'x50'), I'm wondering if this tractor/blade combination will be able to get the job done?
Second, I would like to get any advise on how to level the ground. I've watched YouTube videos, but they pretty much just show you how to spread gravel. My thoughts is that I just progressively keep setting the blade depth lower and lower, and just keep scraping until it seems level. Then use stakes and string to see how levels it is, and fill in low spots until it's level. Probably a lot easier said than done.
Thanks!
This works for me but I am a die hard DIY animal, and I am assuming you personally are building the thing.
Depending how much existing soil has top be moved will determine if you can do it with what you have. If you just need to scrape a little topsoil off and spread gravel around, I would try it. You need to get down to the subsoil for a good floor to hold up. You might need a 3 point dirt scoop to dig down and haul away if you need to go down far at all or if you need to dig out some mounds. To level the gravel, you can do that with what you have. I use small clear stone because it doesn't settle out much but whatever they use by you, go with that.
If it doesn't work with your tractor then call someone in to help.
I would find a cheap transit for ease operation, and that will get you real close to the correct floor height. Find, square, and mark your corners and go to it. I have used a string and a string level, but that is a tough way to do it. I put the transit pole on a platform and set it on the dirt or the gravel base, then take a reading to see if I need to go up or down. It is easy that way.
