dngspot
Bronze Member
- Joined
- Jan 8, 2009
- Messages
- 73
dngspot,
I have been looking at youtube videos for the better part of this evening to see how Ken Tools tire changer works and also some pretty poor videos using the HF tire changer. I've had the equivalent of the HF changer for a few years and haven't used it much, even though I've changed quite a few tires. Mine isn't bolted down so I basically only use it to break the beads.
Your posting today gets me to wanting to use mine in a better way and I have a few questions.
1. Is yours bolted down permanently? I don't have the room to do that.
2. The pipe you are using for the bead breaker looks like a piece of angle iron. Could you post some close ups? How did you get the pipe to look like a bead breaker? Did you replace the HF breaker or reinforce it with the pipe?
3. The Ken Tools Snake looks like a real labor saver. Are these available locally or did you get a knockoff at HF?
4. Would the 42" Snake work on smaller tires than car/truck tires? Or, would a smaller one be needed for smaller tires?
5. What is the price of a Snake?
Thanks for any answers that you have time for. And thanks for starting this thread.
Clem
1. I drilled into the concrete and installed 4 3/8 inch anchors. I simply bolt it to the floor for use, then remove it when done. The process takes about 5 minutes. The unit is set up in an area that my wife parks in, in a two car garage.
2. The bead breaker is the same unit that came with the machine. I cut a couple of plates to attach to the two legs that attach to the pipe via a clevis pin. I then welded the plates to those legs at the bead breaker shoe, and about 2.5 inches below the top of the legs. There are two plates one on the front and one on the back of the legs. The pipe goes into the adjustable pipe that attaches to the legs of the bead breaker; it is thick wall pipe I got from work, and looks like simple black gas pipe.
3. I do not have the Ken Tool Snake yet. I know that Ken Tool has a distributer here but can bet that when I go to see them they will tell me that they have to order it, this seems like the way of life here in Wichita. After I see them and verify their price I will order it from them or on line. I know they can be had for about $52.00 on line.
Harbor Freight does not have a Ken Tool Snake knock off. I bet I would bend it if they did.
4. A 4 foot snake would be a bit over sized, but I bet it would be manageable.
5. Answered in question 3.
This is a pic of the anchors.
Close ups of the breaker.
Anytime,
David
