Sigarms
Super Member
Would those mini splits be ducted? What would the air handler do if there were mini splits installed?
Mini split would use a ducted air handler (multi position, 4 way) or could use a coil on a furnace. At that point, you would still be able to run numerous indoor mini splits off the same outdoor unit that you have the air handler or coil connected to.
Keep in mind, most mini split manufacturers already have dedicated horizontal ducted units, but the static pressure generally sucks for those. The key is using a multiposition air handler with a inverter outdoor unit that you can connect to your standard duct work.
Thing is, EVERY United States manufacturer of split systems have a inverter system, multi position ducted air handler avialble out now for residential retrofit. The reality is the US manufacturers generally out perform the mini split line for both SEER and heating capability vs the overseas mini split manufacturers. Added the fact that parts availability is generally better from US manfuacturers and most help is done within the US. This is where the US has a leg up over their overseas competition.
Personally, IMO, if you already have ductwork, there really is no reason to use a overseas mini split manufacturer if you're just replacing your current ducted system.
Mini splits really shine in heating and cooling areas where ductwork can't be run IMO.
Keep in mind, I've been pushing mini splits for over 20 years now, even when contractors were calling them "voodoo magic" that really don't work LOL I do like them (mini splits), they just aren't the greatest thing since slice bread depedning on the application though IMO for the US market.
