lugnut1009
Bronze Member
I bought a MF 135 and want to use the auxillary hydralics. My valve is under the seat and has a handle which can be rotated from forwards on the tractor and moved 180 degrees to pointing backwards.
I am unsure of which way to move the handle to use the auxillary. I have moved this in conjunction with moving the 3 point handles.
When I attached my log splitter to it. Nothing seems to work. When I rotate the handle straight up and move 3 point handles back, nothing happens. I can walk back and lift the splitter and it will raise.
Any Ideas? I have not found the combination to make the 3 point or the auxillary valves work. I realize that both of these can't work at the same time and that is no problem. I would just be happy if either one worked seperately.
My MF135 has the auxilary valve also, and I don't know a lot about it, but I do know that it won't do anything if the original 3 point lift is down all the way. It almost seems like the original lift control acts as a flow control or something. I leave mine full up all the time. On my auxilary valve, the left is my 3 point lift and the right is (was) for the auxilary outputs, I have them plugged right now.
Not sure I helped, but at least shared my experience.
