spruce Deere
- Joined
- Feb 1, 2009
- Messages
- 1,081
- Location
- Northmost Idaho
- Tractor
- John Deere 790 with loader LS xr3140h also with loader plus a cab
Was fine tuning the tree planter mounted on the 790 for the upcoming planting session, wich is very soon coming, and in the middle of everything the fel just up quit.... was not even using it, just going to lift it out of the line of sight and no lift when the lever was pulled or bucket curl. The whole fel is completely dead. 3 point works like gangbusters still, but the fel is a dead ship. So, I backed it into the shop fairly puzzled.
Changed hyd. oil just last fall along with the filter and cleaned the suction screen also, which was more or less free of any foreign matter. The hyd. oil is just slightly over-full for those who will ask about the level of the hyd. oil I did dis-connect and re-connect the loader quick couplers but that made not a difference.
Figgered I would ask the smart folks on TBN if this has happened to them and hopfully a possible fix for a dead fel. Would the load check valves in the scv both stick simultaneously to create a dead loader???
