Brush Brute - Tractor Implement For Quick Brush Removalpallet forks and start ripping, lift high enough to get a chain saw in and start hacking away. ive done this alot because not knowing what im driving into/over with cutter. but rotary cutter and older tractor(not worried bout scratching it up) and cut away. there used to be a loader attachment called a brushbrute or something like that, it was like a stone fork but made for clearing fields/pastures. i looked into them a long time ago and boy were they expensive, but they apparently were very good for such jobs. like i said, brushbrute???? or something like that.
I was using a friends 45HP Kioti (Korean) with R4 tires and no ballast. That tractor is pretty helpless on grass. If we still had our big John Deere (150HP) I would have been done with this task in one weekend.
A Ratchet Rake for your FEL is $400 and not too much different from the much more expensive Brush Brute. Nothing wrong with using a B'hog if you have one, but if you have to buy, consider the Ratchet Rake. Mine does a great job tearing out thick wild grape vines. RR will be safer to use than a B'hog.
I would then spray whatever new growth emerges with Dupont Cimarron Plus. I hate to spray herbicides too, so use one recommended for eradicating blackberries.
DuPont? Cimarronョ Plus herbicide on broadleaf weeds and brush
And that tractor NEEDS a cab!
Bruce
