RalphVa
Super Member
- Joined
- Dec 19, 2003
- Messages
- 7,873
- Location
- Charlottesville, VA, USA
- Tractor
- JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
Good summary, Michael.
I use a tension cord stretched across and underneath the PTO shafting to help hold it up.
Didn't discover that PTO shield that moved until the guy who delivered my MacKissic showed it to me. Raising it helps.
Moving my PTO selector to the forward PTO location allows the rear PTO to free wheel.
JD provided a PTO shaft on my MacKissic that has a push button. I find this works easier than that collar on the PTO shaft they provided for the LX4. It seems you're working against yourself in pulling that collar back when you want to push the PTO forward onto the shaft. Bad ergonomics.
I always clean off the PTO and reapply white grease to it when putting a new implement on.
I didn't go with iMatch. One reason was the KK carryall isn't compatible. Another reason is accessibility to the PTO. Still another reason is that I've found that having castors underneath implements that don't easily slide (like the carryall and LX4) makes it a whole lot easier to affix the lift arms. I've tri-castors at the ends of a 1 by underneath the front of the LX4. Can roll it around all over the basement floor.
Ralph
Ralph
