</font><font color="blue" class="small">( it depends on which end of the PB hose you are using )</font>
Just what I thought. That does make a difference. /forums/images/graemlins/wink.gif
If I understand all this correctly, you take the PB hose from the original valve loose at the tractor; not from the valve, then run that hose from the PB port on the original valve to the inlet port on the new valve, then run a hose from the PB port on the new valve to the tractor, where the original PB hose was connected. Then of course you need to run a hose from the outlet port on the new valve to wherever the outlet hose from the original valve is attached, probably by putting a tee in the line from the outlet port on the old valve, so the outlet port on both valves is now going to the sump or reservoir.
I think that's the way to fix what we're talking about if I'm not confused, too, by now. /forums/images/graemlins/laugh.gif
