Homemade dingo brush cutter
   / Homemade dingo brush cutter #1
Msc2177
Blue ridge ga
Toro dingo tx425
I am building a 42" bush hog for my dingo tx425. It will have a 5.9 ci hydraulic motor
Going thru a 40 hp 1:1 gearbox.
A few more pics. I put hinges at the top of quick attach for mowing up slopes
   / Homemade dingo brush cutter #3
Cool! What hydraulic flow rate does the motor require?
   / Homemade dingo brush cutter #4
Pretty sweet so far. Are you going to have a pair of castors or skids at the front to limit the cut?
It is rated for 15.8 but my machine only puts out 11gpm. It should still turn 550rpms
   / Homemade dingo brush cutter #6
Looks great! I've never seen a mower on a Dingo or the like but it looks like a great idea. Just don't hit any yellow jackets.
I will put 3" flat bar along the bottom for skids. Not sure if I'll need the castors yet.
   / Homemade dingo brush cutter #8
Will you need to install a hyd. oil cooler for continuous operation?
I don't believe I'll need an extra cooler. A lot of dingo attachments are built for continuous use. It has a cooler now with an electric fan mounted to it.
