Homemade garden tractor ramps
   / Homemade garden tractor ramps #1
Craig Clayton
Platinum Member
Uxbridge Ontario Canada
L2250 Kubota
Gentlemen
This was a quick project using electrical trough cable trays, they were being thrown out. The ends that I bolted on are what I thought might be of interest. They are 1/4" aluminum checker plate that I cut with my angle skil saw. They are designed to operate between 18" and 42" range. I caused a slight bending on the tongue like that of a table fork.The tip will not load at 18" or point up at 42". I bent them in the hydraulic press as shown, it is now a piece cardboard for the picture.
I figure each ramp to hold 250LBS and they a 9" wide by 10 feet long, and can be ganged as shown. So 1000 LBS if they are covered with plywood and clamped together.
Craig Clayton
   / Homemade garden tractor ramps #2
They look like they are as strong as the commercial ones, at least the cheap commercial ones for sure! :D I wouldn't be too quick about putting plywood on them, it won't add any strength and will make them heavier to handle plus plywood can be slippery as all get out!:eek:especially if wet. The extra length of them (over store bought) should make them much more user friendly! Nothing worse than getting hung up with a low ground clearance machine on the top end of ramps because of too sharp an angle.
I give them :thumbsup::thumbsup:
   / Homemade garden tractor ramps #3
One of the worst things about ramps is the possibility of slipping, especially when you put metal on a plastic bedliner. One thing you might do is glue a nonslip cushion type material to contact area of the ramp lip. You may have a better plan of your own.
Nice looking ramps.
