has anyone built a homemade livestock trailer? i am in the process of building one now and so far have the frame(2"x2" sq. tubing) already tack welded. i am having a devil of a time getting the "T" butt joints of the frame/crossmembers welded correctly. it seems that when i weld down the seam and chip and brush the slag, i have a gap that did not weld. what causes this? this is my first "big" project and the first time i have had such a problem. i am using a 3/32" rod #6013 on 90 amps to weld 1/8" wall tubing. i tried to "surf " around with different amps and rod sizes, but no good either. even tried to run a bead on each side of the joint and then one down the middle and that is even worse. seems like nothing will "bridge" the gap. i would greatly appreciate any hints or ideas as to what i am doing(or not doing) wrong on this.
