I'm about to do a test this weekend and was thinking about this some more. Here is my test to isolate the issue from a cylinder seal vs spool leak (remember, there is NO external leaking of oil in my system):
1. If I raise the loader, put a block under it, remove the hose on BOTH the extension and retraction side of the cylinder so the test is isolated to the cylinder and not the valve, and remove the block under the loader...
a) If loader drops then there is a cylinder seal leak in one or both cylinders
b) If loader stays then there no cylinder seal leak
Now lets say the loader stays in the above scenario confirming that the there is NO cylinder leak. Then I can confirm the spool valve leak by...
2. If I swap the hoses to the extension/retraction loader cylinders, then raise the loader by moving the joystick in the down position until the front wheels are off the ground...
a) If the loader does not drop and tractor does not sink back to the ground, then there is a leak in expansion spool
What do you think?
What do you think?
