Hooked_on_HP said:Monte, your control valve should have its own pressure releif valve. It will screw in to a port in the valve. They are usually about an inch and a half long. Sometimes it has a cover over it that unscrews so you can adjust it. You should have a pressure guage hooked up when you try to adjust it.
There's one thing on the valve that might be what you describe. It's not inline with either of the spools. Looks like you use a large screwdriver to open it up, though it has a good 27 year coat of rust on it. I'll start with some penetrating oil and see if I can get it loosened up and see if that's the relief valve. I think it's on the pressure side of the valve, if that makes a difference.
Monte
