at moment with some old 5 gallon gas cans, that i have labeled with black marker for diesel. but to be honest. it is a pain in rear to fill. having just enough foot hold for just one foot. and having to prop other foot on front tire or frame of FEL. and hardly anything to lean against easily to keep my balance. and by the time i get high enough. it is a chore to lift the 5 gallon jugs right at head height and get them tipped into the fuel hole.
same goes for allis chalmers CA, having the belly mower on, helps give me a little stand to get the gas cans up, and tipped. but still fairly high.
i have been tempted to get some pulleys and some cable and some hooks. so i can place pulley up high in the shed, and just lift gas can straight up on the pulley cable. and then tie off. so i can put gas into the allis chalmers CA tractor.
but for the ford 555c TLB and diesel, tractor to big to fit in shed.
i have a couple 300 gravity tanks that set up on a stand. but they are to large for amount of gas and diesel i go through in a year. and i am not real keen of having to add extra preservatives or dealing with moisture.
that and having gas and/or diesel delivered, has been a costly venture, the couple companies near me, end up charging any were from 10 cents to a buck more than what the price is at local gas stations.
if i had a pickup truck, vs a blazer, i might opt for a gas tank that fits in back of the pickup truck. some are built in L shape. to fit under a tool box. this would be a good option for me.
if i had a large size pickup truck, i might see how much it would cost to get a second tank placed under the bed. and then just fill up rear tank. and instead of hooking second tank up to truck, just place valve and pump on it. so i could fill up something else up.
i have been tempted to get a plastic 55 gallon drum, or perhaps a metal drum. and just strap it down onto a trailer and haul it into the gas station and fill it up. and then once back home. use the FEL on tractor to move it off trailer and put some place. with a hand pump or 12v pump on it. but after reading through regulations for Illinois i am not sure if that is legal. and looking at fines. i was discouraged.
i was more discouraged, about permanent gas tanks vs portable gas tanks for storage of gas and of diesel. and reading needing double wall tanks and if not double wall a catch basin and blah blah blah. my mind just went blank and gave up.
i would most likely be less discouraged if i understood the regulations better, and could set something up. so i would not fear of going BOOM! after reading through "grounding wires" so you do not create a spark just from static electricity. with a permanent tank and filling a tractor up. has me on edge even more.
so for now, it is 5 gallon gas cans, and waiting to see a good deal on 12v or hand pump for gas and then one for diesel. and them some tanks both for hauling back and forth between gas station and farm, and then some tanks to store the gas and diesel here on the farm.
