how obvious/visible is water in the diesel fuel filter?
   / how obvious/visible is water in the diesel fuel filter? #1
ratropia
I pasted the same message on the NH forum. Sorry for the double post, I should have posted here first.
TC-30. 45 hours. How obvious/visible is water in the diesel fuel filter bowl? I am at 45 hours and am starting the 50 hour maintenance program . So I did the fuel filter first. I did not notice any water in the bowl. What should I have been looking for? Is it obvious? Or only if there is quite a bit?
Thanks.
BTW I use 5 gallon cans. I think I may find a better way. At least a pre tank filter.
Rick T.
   / how obvious/visible is water in the diesel fuel filter? #2
Water will settle to the bottom because it is heavier. You will see it, looks like a blob of clear jello in diesel fuel.
Chris
   / how obvious/visible is water in the diesel fuel filter? #3
I've NEVER had water in diesel fuel in either of my Benzs (55k miles on first and 183k miles on current one) nor in the fuel bowl on the tractor the 3 times I've changed it. Should show up as a noticeable blob in bottom of the bowl. The fuel may appear a tad cloudier than normal. I've seen it (water in fuel) while working in petroleum industry, just not in my cars or tractor yet.
Ralph
   / how obvious/visible is water in the diesel fuel filter? #4
It's as the others described it, usually if there is any at all it isn't much. It mostly will come from condensation in the tank. The only time I ever got a large amount of water was by using a 55 gallon barrel as a portable tank with a rotary hand pump. The design of the pump let rain water run down the side if the tube and into the fuel. It sat in the back of the truck during a week of rainy weather and acquired enough water to fill the filter, lines, and injection pump and kill the tractor. Cleaning out that mess taught me to be more careful.
Just look in the bottom of your filter bowl before you start your tractor ocasionally. The bubble of water will be distinct and settled in the bottom of the bowl.
   / how obvious/visible is water in the diesel fuel filter? #5
I closed the duplicate thread in the other forum, but don't really know how this thread got closed, too.:confused: So anyway, I'll re-open it.
   / how obvious/visible is water in the diesel fuel filter? #6
Thanks Bird.
Rick,
On my JD 4700 the clear fuel bowl has a red ring that normally sits at the bottom of the bowl. If there is water in the bowl said ring floats.
Maybe your fuel bowl has a ring and you don't see it since you don't have water?
If no ring maybe you can put one in?
It sure makes it easy to check the fuel for water.
Later,
Dan
   / how obvious/visible is water in the diesel fuel filter? #7
Any amount of water...........no matter how small will seperate out and be visible in the sediment bowl.
Sincerely, Dirt
   / how obvious/visible is water in the diesel fuel filter? #8
This is NOT a good example but it is real close to diesel with water
diesel/water ?
Don't mix them
Jim
   / how obvious/visible is water in the diesel fuel filter? #9
If you have ever had a vinegret salad dressing? Similar look when it sits. You see the oil, yellowish (road diesel yellow), clear on bottom (water). IF off road, red on top.
   / how obvious/visible is water in the diesel fuel filter? #10
My experience has been the filter " freezes " and will not allow fuel to pass through. There is no indication of ice or water in the filter base. My 55 is stored in an unheated section of a building and will run fine for about fifteen minutes outside be fore shutting down.
This last time I took the filter out ( it looked normal ) but I couldn't get fuel to flow through it. I took a hair drier and heated it up and dried it out. Upon replacing the same filter I noted it worked fine. At eleven dollars a throw the cheaply constructed element isn't my first choice. I will be researching a better system that is more dependable. Working in this tight area isn't a real picnic either. I have added drier, conditioner, as well as kept the tank full of current fuel which doesn't seem to make a big difference. A water seperator may be what is called for.
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A53421)
2023 Caterpillar...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2022 Chevrolet...
Hose Reel (A55758)
Hose Reel (A55758)
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
16FT BUMPER PULL SPOOL TRAILER (A55745)
16FT BUMPER PULL...
