If it is aluminum and #8 wire, ensure the breaker is a 30 amp and no larger. In applications where you must attach Cu to Au, I use either split or even better, the tube type with set screws that uniformly crush the wires into the conducting tube. The drawback is you need room in the box to fold them back. Also, be careful of how you strip aluminum wire, if you score the wire with a knife, you risk breaking off that strand.
