After my neighbor machined my CAT2 pins to CAT1 dimension, I Managed to get the JD609 attached. This was in the fall of last year. I am at the outer limit for my sway brackets. I then wound up the RPM's, and was very pleased with how smooth this older unit runs. I took it over some soft grass, then some small trees. WOW what a unit. The Power and sheer mass pulverizes anything you can push over. I am amazed and very respectful, of the power this brush hog has. One thing I need to figure out is how to attach safety chains to the PTO shaft cover. This PTO shaft cover is substantial. (heavy steel with poly/plastic underneath. (next to revolving shaft)
I am still trying to find 2 1/2" Open End Wrench, to correctly adjust the Slip Clutch, before this year's mowing starts. I also plan to run the unit, get the oil warm, and change it.
I also will be attaching the debris guards front and rear. (most likely will go with the less expensive rubber, since I have no need for the more expensive chains) All I need now is a large 3pt spreader; (to prep my crop plots with pelletized lime, and fertilizers) and cultivator/disc. (to work leaves/grass/manure/mulch into soil) I really appreciate all those that have contributed to help me out. I am amazed at the speed and force of these machines, when properly equipped.
