ryanbr
Bronze Member
- Joined
- Jan 24, 2008
- Messages
- 53
- Tractor
- White 2-105, Cockshutt 770
i would also try building a cheap, three or four legged perch out of 2x4s that would hold up the sheet a couple of inches from the ceiling. slide the board up on the perch, then use a simple floor jack and a t-bar our of 2x4s to hold one end up firmly. go to the other end and use your hand to press that end into place and put in a few screws. go to the other end and screw it in. lower jack. move scaffolding to next location. finish screwing board in place. repeat.
just out of curiosity, what does osb have to do with insulating a garage? doesn't the insulation just staple up between the rafters? and if you want it finished, isn't drywall cheaper? or how about foam board with a reflective coating on the down facing side? much lighter than osb and adds even more insulation. just curious....
amp
Using OSB to sheet the roof in prep of blowing in insulation. I decided not to strap it instead just poly and sheet. Once complete I will blow in the r40 insulation (15")
OSB is quite a bit cheaper then drywall, we have a local OSB plant (LP). I think it was 7bux a sheet for 7/16. 'Finishing' OSB is quite a bit cheaper for me too since I would have to hire someone to mud and tape drywall. We are planning to stain the OSB since then there is no need to prime and cuts down on paint costs.
As you can tell im trying to do this on the cheap since its the cost of the insulation is really high in my part or the world.
