How to Hang a 450-Pound Barn Door By Yourself
   / How to Hang a 450-Pound Barn Door By Yourself #1
jcaron2
Madison, NC
Kubota MX-5000
I recently finished building the doors for my horse barn and was faced with the task of hanging them without help from anyone but my tractor.
There are four main doors (a pair for each end of the barn), each measuring 6'x10'x3" and weighing around 450 lbs, along with two side doors into the wash rack which measure 9'8"x4'8"x3" and weigh around 350 lbs apiece.
If I had superhuman strength or several helpers, I'd simply lift each door up to the end of the track, then slide it sideways into the track. With my tractor I could accomplish the lifting part by strapping the door to the bucket, but I would then have no means of sliding it sideways. What to do?
I had to give it some thought, but the solution was fairly simple:
Step 1: Mount the rails on the outside of the barn.
Step 2: Roll/slide/build in place or otherwise manhandle the door over to the door opening.
Step 3: Stand the door up on end and lean it against the tractor bucket.
Step 4: Strap the door to the bucket, lift it, and tilt it toward.
Step 5: De-mount the rail from the outside of the barn, install the door slider hardware onto the door, and slide the rail onto the top of the door.
Step 6: Position the entire door/rail assembly in place with the tractor.
Step 7: Remount the rail onto the barn using the same bolt holes as before. Remove the straps and back the tractor away.
There you have it!
   / How to Hang a 450-Pound Barn Door By Yourself #3
Uhmmmmmm Ok..... You really win... There is no way my tractor would not leak down to begin with, second, there is now way I could realign the door rail perfect enough to get the holes to line up.
Frankly, I am very impressed.
Where did you get your door hardware BTW?
   / How to Hang a 450-Pound Barn Door By Yourself #4
Another great use of a tractor, 2 guys would of really struggled with that thing.
Beautiful looking building.
   / How to Hang a 450-Pound Barn Door By Yourself #5
He cheated...the dog was helping thru use of a harness that he kept outta site of the camera to try to impress us.:)
Great job and nice barn!
   / How to Hang a 450-Pound Barn Door By Yourself #6
12pack or 30pack? Your dog had it all under control anyway!! Nice job!
Keep in mind that the rail is free to move left and right by several feet, so lining it up in that direction is trivial. There's maybe an inch of play with the height since the inside of the rails is about an inch larger than the diameter of the roller wheels. The biggest challenge is getting the door plumb, so that the rail will be level and will line up with the holes all the way accross. At first I tried whacking the door with a sledge hammer to knock it plumb. Then I realized I could just back up a few feet, put down a scrap board or two in front of whichever rear tire had to come up, and just drive up onto it. Add in the extra inch of slop and it's really not too hard. It does help that my loader doesn't leak down though! That would really make it a challenge.
I bought the hardware at Tractor Supply. Just their standard National line. It seems to work pretty well, but TSC doesn't seem to stock any of the extras like bottom guide rails or flashing kits, so I'll need to find those elsewhere I guess.
   / How to Hang a 450-Pound Barn Door By Yourself #8
I think he did it all with Photoshop!!!!
Very impressive... been there.
Lloyd
   / How to Hang a 450-Pound Barn Door By Yourself #9
nice! you got er done!
   / How to Hang a 450-Pound Barn Door By Yourself #10
Great use of the equipment and great looking doors and barn.
I'll say those doors are heavy. The doors I built years ago were lighter BUT, I nearly killed myself putting them up with no help and no loader. Yuk.
I put the rail up, positioned the door next to the rail with boards under it and got the trolleys close to going in, had the door angling down hill away from the rail. Then climbed a ladder and "persuaded" the trolley in a little bit. Then got down the ladder and tried to lift the opposite corner to get the trolley to slide in. But most of the time, it slid out. After about a half dozen tries, I might get lucky and get one trolley in the rail. Then it pretty easy from there with the rail holding up about half the weight.
I'm sure my back would be in better shape today if I had bought a front end loader a long long time ago. Built 2 horse barns and managed my "kids" horse farm for 2 decades without a loader. Silly me.
For those guys out there saying they don't have any use for a loader. You really really do.
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2012 International 4300 Reefer Truck (A57024)
2012 International...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2019 KUBOTA R630 WHEEL LOADER (A52707)
2019 KUBOTA R630...
2019 Ford F-250 Super Duty Crew Cab (A55852)
2019 Ford F-250...
