JulianKo
So I paid big buck to buy the only MF 1217 backhoe I could find, because that is the stock backhoe made for my tractor (MF1240).
And what a surprise... Something does not match and I cannot mount it.. I need help from someone who has this backhoe on a 1240.
The backhoe manual suggests that the backhoe attaches to the tractor via two brackets in the rear (not clear to me where and how those brackets should attach to the tractor) and two front mounts (my tractor has those front mounts).
However the backhoe came with some additional frame pieces attached to the brackets. After playing with it and comparing to the manual, I am starting to think that those additional pieces are not necessary in my case (probably the backhoe came from a different tractor, but we don't know what).
On picture 1 you can see the backhoe subframe, the brackets and the additional framing attached to the brackets...
On picture 2 I removed the additional framing. Should I leave it out? It is showing just the brackets, but they seem offset and don't seem to match my tractor
On picture 3 I am showing the brackets under the tractor rear axle as the backhoe subrfare lays centered under the tractor. See how the brackets are not centered under the axle bolts. How and where should those brackets mount?
