EddieWalker
Epic Contributor
Is the water coming from inside the ducts? Condensation will form on the outside, not the inside.
If water is coming from inside the ducts, you need to figure out why and address that problem. They should be dry on the inside.
I like foil tape. It's kind of pricey, but it works great at sealing metal ducts. It's especialy nice to use in tight spaces and where you can't see what you are doing. Like the backs and bottoms of the ducts.
Once you get them sealed, then insulating them is a very good idea.
You might also price what it costs to buy flexible, insulated ducts and just replace what you have. If it's not a huge run, you might be better off with something new. I've done both, and replacing can be be much faster and more efficient then trying to get the insulation around those ducts in tight places.
Good luck,
Eddie
Good luck,
Eddie
