chh
Veteran Member
If it has power shuttle then it has an electro hydraulic clutch period. That is what a power shuttle is. All they have done is added a shift button.
EhM8 said:Again, I am not talking about powrshift, Dynashift or IVT. I am talking about this power clutch button they've added to synchromesh transmissions. If it doesn't provide clutchless shifting - it is a button that disengages the clutch - then it is a pretty superfulous and untidy option instead of providing a true powershifting option.
slowzuki said:Chh is right, the tractors with a declutch button already had an electronic over hydraulic wet main clutch so its like 1$ to add a switch for it.
The clutch pedal on those units are just connected to a variable resistor and limit switches and a spring so they aren't really hard to push anyways but it cost nothing to add the declutch button.
I've driven a few and it is ok to use. I don't think it would make or break a deal.
As for the hundreds of clutch pressings, if you don't have a high-low/dual-speed you spend all day clutching while baling. I borrowed a straight gear tractor on Sat to bale with and I got maybe 100 clutchings an hour, on a very heavy clutch. Someone with hip trouble couldn't do it I'd bet.
chh said:If it has power shuttle then it has an electro hydraulic clutch period. That is what a power shuttle is. All they have done is added a shift button.
Egon said:If you really look at it it is impossible to sell much of anything to a lazy farmer!
They are usually bankrupt!
Solo said:Caterpillar has a similar transmission on its backhoes, IE... 420E. I'm not sure if this is a new feature or not? The new hoe we have at work has this transmission. I'm still trying to get used to it.
You shift by pushing a button on the gear shift knob and then change gears. It is a power shuttle transmission. You also have the option of auto shift on the same transmission. Just flip the switch and it is fully automatic.
Solo
EhM8 said:Do you have to back off the throttle before you use the button, or can you change under full power? If it is the latter, then it would be useful; if it is the former, then it is probably only good for people with bad legs.
