HST Filter Change
   / HST Filter Change #1
central NC
TYM T474
With today's typical HST tractors, do they generally have a transmission filter and an HST filter? My dealer sold me both when I told them I was going to do my 50 hour service. But in all honesty, she was guessing as much as I was and just reading parts numbers from the book. I'm in the middle of my HST filter change and I'm thinking that's all I have. The oil and filter change is done.
   / HST Filter Change #2
Mine has both and I changed both of mine at 50 hrs. . Filters are cheap compared to the alternative . Did you buy some fluid as you may be just a little low now ?
   / HST Filter Change #3
Your manual says there are 2, no?
   / HST Filter Change
Yes, the manual has two filters listed. But I couldn't tell if that meant one for the HST machines and the other for the Synchro Shuttle.
Thanks to most for not being asshats.
   / HST Filter Change #6
What brand and model of tractor are you asking about.
My Deere X540 only has HST filter while my Branson 2400H has implement pump and HST filter.
   / HST Filter Change #7
On Bransons there is a hydraulic system filter and if your tractor has it, an additional HST (transmission) filter. I suspect that's common on CUTS. They both filter the same fluid of course but I think the HST filter is lower flow and may also filter out smaller particles.
   / HST Filter Change #8
Most manuals will call out the location of each regularly serviced filter on the machine with photos or line art.
   / HST Filter Change #9
Could also have just looked under the tractor before heading to the dealers.
   / HST Filter Change #10
Good advice been given (y) also take maker write on the end of filter hours when filters were change...good reminder.
