dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,188
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
JC-jetro said:Dave,
I have a hard time imaging pumping action without an inlet port and outlet port. I have also looked at some axial pump design same as article below suggests. They do mention a valve plate. The rotation of cylinder block against the valve plate seems to me emulate suction and pressure cycle when the cylinder block rotate passed inlet opening(suction) or outlet opening (pressure). You may be able to say there is no valving but I think the function of valving is archived thru rotation of cylinder block against stationary valve plate.
JC,
Axial piston pump - Wikipedia, the free encyclopedia
If you look at Figure 8 that WIKI refers you to, you will see that the
inlet and outlet ports are always open. No valving. (Other than the
pressure reliefs on both ports.)
With respect to the end plates of the axial piston pump and motor, I do not know why they
are called "valve plates". Perhaps someone with more experience with HSTs on TBN can
comment. Seems to me, to be a "valve", you have to affect the flow in some way and
I do not see a poppet, spool, ball, gate, needle, or reed in the end plate. Just slots.
